Activity Forums Adobe After Effects Good graphics card for AE CS5.5? (Mac)
  • Good graphics card for AE CS5.5? (Mac)
    Posted by Art Lee on January 23, 2012 at 12:04 am
    Hi – I am getting an upgrade to AE CS 5.5 and have the option of upgrading the graphics card as well. Have heard that there are recommended cards from Adobe, the AE specs site just says display card drivers that support OpenGL 2.0
    Current card is NVIDIA GeForce 8800 GT, if there’s not much advantage to be gained from upgrading the card I wont bother, but will if it will make a big difference to performance. Any recommendations?
    Model Name: Mac Pro
    Processor Name: Quad-Core Intel Xeon
    Processor Speed: 2.8 GHz
    Number Of Processors: 2
    Total Number Of Cores: 8
    L2 Cache (per processor): 12 MB
    Memory: 16 GB
    Bus Speed: 1.6 GHz
    Chris Bobotis replied 14 years, 7 months ago 4 Members · 3 Replies
  • Brian Charles
    January 23, 2012 at 12:44 am
    After Effects doesn’t significantly benefit from the graphics card. OpenGL is flakey in AE and most users disable it.
    If you use other applications, like Premiere Pro or a 3D app that uses OpenGL, you’ll see a speed gain there, but not for AE.
  • Tudor “ted” jelescu
    January 23, 2012 at 3:37 pm
    I would not worry too much about the card- like Brian said AE does not really like OpenGL to the point where even Adobe does not recommend using it. Unless you plan to use 3d plugins like FreeForm Pro, ShapeShifter AE or Invigorator Pro, upgrading the card will not help. Even if you do, since you’re on a Mac, to get a card that will make a significant difference for those plugins will be expensive – on a PC even a $150 card will offer improvement.
    I would get more RAM if you got the budget, max out your machine and that will significantly improve AE performance!
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Chris Bobotis
    January 25, 2012 at 7:43 pm
    On the Mac the GTX series by NVIDIA is the best bang for the buck right now. Get a card with as much VRAM as your budget will allow.
    RAM and fast disk(s) help too – especially with 5.5 now that the AE team has changed the caching scheme fast disks help quite a bit.
    HTH
    Cheers,
    Chris
    mettle.com
