Activity › Forums › Apple Final Cut Pro Legacy › Good Dual Layer DVD burner with lightscribe?
Posted by Patrick Morrow on May 23, 2006 at 2:19 amCould someone recommend a good DVD burner with lightscribe? What are the pros and cons of such a unit as I do not have room for a dedicated printer and only produce a few DVD’s at a time.
Thanks!!!
Patrick MorrowRon James replied 20 years, 4 months ago 3 Members · 2 Replies -
David Bogie
May 23, 2006 at 2:11 pmI have never met anyone who has used Lightscribe successfully more than once. But that’s just my small circle of pals.
Almost any burner can be programmed to use the software, the list is quite long at HP or here:
https://www.cdrinfo.com/Sections/Reviews/Specific.aspx?ArticleId=13449
Is the software even available for Macintosh? Requires special media, too.
https://www.lightscribe.com/support/index.aspx?id=179
You’ll be much happier with a printer, expecially if you hand these disks to a client. If you’re not giving them to real people, a Sharpie will give you better faster more creatively rewarding results than Lightscribe.Q: What Operating Systems are supported by LightScribe?
A: LightScribe is available on Windows 2000 and XP and supports Mac OS X 10.3 via the Lacie DVD+/-RW external Double layer drives and DVD +/- internal drives.
Q: Can I install a LightScribe enabled drive in my Mac?A: Although most LightScribe enabled drives can be installed in a Mac system, they will not have the required LightScribe System Software or Labeling application to make the process work unless specifically provided with the hardware or purchased separately. LaCie is a Licensee providing a complete hardware and software solution. Also, SmileOnMyMac, an Independent Sofware Vendor, provides Mac compatible Labeling Software. See related FAQ. Note that a Mac compatible LightScribe System Software (also available at this site) is also required in order for this software package to work.
Q: Can I install an internal LightScribe drive in an aftermarket external drive case?A: Only LightScribe drives sold as a complete external drive are currently qualified and supported. Many third party external drive cases have not been tested and may not function properly for LightScribe labeling due to communication protocol conflicts with some interface hardware sets.
bogiesan
Ron James
May 23, 2006 at 11:24 pmI think you can just buy a LaCie lightscribe burner. Not sure that just any burner can be used. Usually they’re labelled as Lightscribe burners.
Actually, the labels don’t look too bad if you use a picture with a lot of detail and contrast. Not the best looking, but way better than handwritten. I find some inkjet labels can look pretty cheesy. It’s really about knowing your limitations and being creative, just like anything. Best thing about Lightscribe is you don’t have to wait 24 hours for each one to dry. When it’s done, it’s done.
The downside is that the discs are expensive and hard to find. But worst of all, the Mac version of the software is really lousy. I’ve seen the windoze version and it’s got a LOT more features and control than the Mac version. It’s clunky and unreliable, from my experience, despite what LaCie will try and tell you (that it’s solid and any quits or crashes are usually due to OS problems – yeah, sure).
You can find pictures of sample discs on the internet, from real users, if you’re interested in seeing how one looks. I’d probably go with inkjet, if I had a choice, FWIW. Cheaper media and the option to use colour.
HTH
G5 Dual 2.7 GHz
2 GB RAM
OS 10.4.6
FCP 5.0.4
QT 7.0.4
