Activity Forums Maxon Cinema 4D Golf Ball Dynamics ?
  • Golf Ball Dynamics ?
    Posted by Chris Tabor on May 18, 2008 at 4:08 pm
    I have a scene that looks like this:
    https://tabortwins.com/ftpstuff/lpga.jpg
    What I am trying to do is have the golf ball come in from behind the camera and bounce off the 2 logo’s and land in the grass. I can’t get it to look right keyframing it, so i am trying to use dynamics. I can get the ball to drop straight down but not have forward momentum. I tried using wind to blow the ball into the scene but i feel like i am totally off on my approach to this. Can you use a spline path and still respect collision properties? Then i could keyframe the ball into the first logo and have dynamics take over… I tried baking the dynamics and the modifying the keyframes but that has the momentum still as droping from straight down. Ug, i am a noob…
    Kris Cook replied 13 years, 6 months ago 4 Members · 15 Replies
  • 15 Replies
  • Brian Jones
    May 18, 2008 at 4:47 pm
    That’s what the Start Tab is for in the Rigid Body Dynamics Tag.
    “The ‘v’ settings define the starting velocity of the rigid body. The ‘w’ settings set the angular velocity (rotation). ‘F’ defines a force that is exerted during the first frame of the dynamics animation. The values you enter for ‘I’ will define the torque applied during the first frame of the dynamics animation.”
    So you can set a starting speed and let it run. Like this.
  • Chris Tabor
    May 18, 2008 at 5:38 pm
    OMG… You could not of been more helpful unless you came to my house and did this for me!!! THANK YOU!
  • Chris Holland
    May 23, 2008 at 6:13 pm
    Chris,
    Did you use the Hair module for that Grass ? ThAnks.
    Chris Holland
    Editor/Animation/Design
    hollandedit.com
  • Chris Tabor
    May 23, 2008 at 6:37 pm
    yes I did… I am still relativly new to cinema 4d. Is there a better way? What did you think?
  • Chris Holland
    May 23, 2008 at 6:58 pm
    Chris,
    I am new at Cinema 4d as well but I thought it looked great. Did you put it on a huge sphere or is that falloff from the camera ? I don’t know a better way to do it. I don’t even have the hair module. Thanks.
    Chris Holland
    hollandedit.com
  • Chris Tabor
    May 28, 2008 at 7:10 pm
    Not a sphere. It’s on a small landscape to keep the count way down.
  • Kris Cook
    February 26, 2013 at 7:51 pm
    Any chance of resurrecting this bad boy from the dead and reposting that file?
    Will love you longest time 25 dollar and a bag of rice.
  • Brian Jones
    February 26, 2013 at 7:58 pm
    I probably have the file still but it would be using the old dynamics I’ll bet, what version of C4D are you using? I can remake it with the current dynamics (once I open it and find out what it does)
  • Kris Cook
    February 26, 2013 at 8:12 pm
    Amazing! I’m R13 – happy to tinker around with an old file though – not sure how much has changed since? I joined around R12 days…
  • Brian Jones
    February 27, 2013 at 1:40 am
    I do have the original but it does not work in 12+ What version of 13 do you have? Do you have MoDynamics (I have 14 Studio so I would use Dynamics but you might not have that)
