Activity Forums VEGAS Pro going to architect from desktop.
  • going to architect from desktop.
    Posted by Doyal Gudgel on June 1, 2011 at 4:20 am
    Can Architect 4.5 be installed separate from vegas nine? It is separate in control panel but I don’t see anyway to put a shortcut on the desktop. In Vegas nine every time you want to make a movie you have to render what ever you are working on in vegas nine then send it to architect. Have a nice day.
    Doyal Gudgel replied 15 years, 3 months ago 2 Members · 8 Replies
  • 8 Replies
  • Mike Kujbida
    June 1, 2011 at 1:19 pm
    On my XP machine, I go Start – Programs – Sony – DVD Architect Pro 5.2 – DVD Architect Pro 5.2, right-click on this last one, drag it to the desktop and choose “Copy here”.
    You may need to do something slightly different depending on what version of Windows you have but the concept is the same.
  • Doyal Gudgel
    June 1, 2011 at 3:59 pm
    The problem is I cant do that. I find it in Control Panel as a program but not in list of programs or a shortcut on desktop. I can only find it by going from vegas nine into sending the project to be made into a movie in architect. But to do that it renders it again. I installed it from a disk but don’t remember having the option of putting a shortcut on the desktop. Its a bummer to have to go through vegas 9 every time. I use windows 7. If I don’t find anyone with a ready answer I will go back and see if I missed something in the installation process.
    Have a nice day
    D
  • Mike Kujbida
    June 1, 2011 at 4:54 pm
    Open up “My Computer”, go into Program Files, find the Sony folder, look for the DVD Architect folder, find the DVDA exe file and make a shortcut on the desktop from that.
    Once again, I don’t use Windows 7 so the steps may be slightly different.
  • Doyal Gudgel
    June 1, 2011 at 6:19 pm
    Thanks for trying but the usual way of doing this only shows previous files. This is deliberate on Sonys part I think. In vegas nine and unless you have media in the timeline you can not get to Architect. It can not be installed without installing the whole program from the disk. Of course Architect is useless without vegas.
    and vegas is pretty useless without architect. I’m pretty sure I am not alone because someone previously wanted to do something in architect without the dar. That cant happen of course.
    I think when you get to architect you can pick out other previously rendered projects to work on. I am burnt on this and because I looked at all the fine print on the box to make sure it did what I wanted it to do. Then I find it would not. That the print was just that. But all this is an afterthought so I will just run with what I got. Unfortunately I have re-registered and am on the moderated list. I will have to see if the moderator has the guts to post this negative post. But I look on this vegas 9 as just something to sell their pro version. I’m 90 in 2 months and didn’t think I had a naive bone in my body but this goes to show ( this seals this to the round file) There is a sucker born every minute.
    Have a nice day.
    Love ya
    Doyal Gudgel
  • Mike Kujbida
    June 1, 2011 at 6:25 pm
    Doyal, I have no idea why you’re having so many problems.
    I know a few Movie Studio users (they bought it on my recommendation) and they’ve been very happy with the software.
    They do not have 1/100 the problems that you’re having.
  • Doyal Gudgel
    June 1, 2011 at 7:11 pm
    Thanks. I wrote a long answer then wiped it out. Rome wasn’t built in a day. I have just one problem to solve then I’m ok. I don’t really have a lot in spite of what it seems. I think I know what the problen is. I’ve got to check
    See Ya
    DG
  • Mike Kujbida
    June 2, 2011 at 10:16 am
    Once you get it figured out, please let the forum know what the solution was so that anyone else with the same problem can find the answer when they do a search.
  • Doyal Gudgel
    June 2, 2011 at 2:22 pm
    OK, but it will be a work around. I am convinced there is no way to directly access Architect without being in Vegas 9. The other versions I don’t know. Later
    Doyal
