Activity Forums Media 100 Going from HD to 8.2.3
  • Going from HD to 8.2.3
    Posted by Wayne Abler on March 28, 2006 at 4:32 pm
    I’d like to take some media captured in HD and edit it in 8.2.3a. It looks like the only way I can do it is by exporting from HD as self contained clips and then import into 8.2.3a. Problem is I loose timecode that way.
    Media 100 says; “Media 100i is now compatible with Media 100 HD and Media 100 sw. This allows you to seamlessly move media between systems.”
    Is there a way I can preserve timecode and export clips from HD to 8.2.3a. Any suggestions appreciated.
    Wayne
    Wayne Abler replied 20 years, 5 months ago 2 Members · 2 Replies
  • Floh Peters
    March 28, 2006 at 4:38 pm
    If you have digitized in the Media 100 i codec you should be able to fast-import the digitized clips into Media 100 i and keep the TC that way. Locate your video clips in the Finder, copy them to the Media 100 i system and import them there.
  • Wayne Abler
    March 28, 2006 at 11:18 pm
    Thanks Flo
    I think my problem is network related. This morning I transfered the files via ethernet and I couldn’t get them to open on the 8.2.3 system. They will play back in QT player and the get info command shows they’re Media 100 NTSC but they won’t import to a bin.
    This afternoon I copied the same files from my HD system to a firewire drive and everything opened up just as you would expect.
    I can live with sneaker-netting with a firewire drive but for very small projects, the ethernet is faster.
    Wayne
