Activity › Forums › Adobe Media Encoder › Going from DV to DV without recompressing
  • Going from DV to DV without recompressing
    Posted by Göran Thorén on April 24, 2012 at 1:51 pm
    Hi all!
    I have found myself editing an old 4:3 DV Pal and added some minor color correction in PP.
    Now, If I want to export that graded movie and choose DV pal in Mediaencoder, will it recompress that DV file yet again?
    And if all I did was edit the material without adding any effects at all is the right workflow to export the finished edit to DV Pal or again, will it recompress that media?
    I come from Final Cut and In the export dialog you can choose NOT to do a recompress.
    /Husse
    Göran Thorén replied 14 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
