Activity Forums Apple Final Cut Pro Legacy Going between FCP6 and 7
  • Going between FCP6 and 7
    Posted by Kevin Wong on December 1, 2009 at 2:52 am
    I have an editor I work with that’s on a PPC editing system with Final Cut Studio 2. Usually, we’ll both get a drive with all the raw footage copied from P2 cards and one of us will log it and mail the other the project file. I know you can’t revert a project file but I’m wondering if there could be any problems for me trying to log and transfer footage in a FCP 6 project that’s been updated to 7.
    Andy Mees replied 16 years, 9 months ago 2 Members · 1 Reply
  • Andy Mees
    December 1, 2009 at 5:39 am
    Hey Kevin
    You should have no problem receiving FCP 6 logging projects when working in FCP 7 .. you should find the project will update just fine and all logging data present and correct.
    If you need to log or edit in FCP 7 and then mail back something that will work just as seamlessly for your co-editor using FCP 6 then be sure to export your project as an XML v4 file (File menu > Export > XML… then choose Format: Apple XML Interchange Format, version 4). A project file in that format should open right up in FCP 6 (File menu > Import > XML…) and your colleague will be good to go.
    Best
    Andy
