Activity Forums Adobe After Effects Expressions “Go to Time” command change?!?!?
  • “Go to Time” command change?!?!?
    Posted by Doug Nash on January 16, 2008 at 6:20 pm
    Hello. I posted this question in the general AE section, to no avail…
    Is anyone else furious with Adobe for changing the time-honored “Command-G” for “go to time, with the absurd “option-shift-j”? What in the world would make them do this? You can barely toggle this crucial command with one hand now!
    So…is there any way to customize such a thing? I did notice that “Command-G” doesn’t seem to do anything now.
    Doug Nash replied 18 years, 8 months ago 2 Members · 4 Replies
  • Filip Vandueren
    January 21, 2008 at 5:51 pm
    Yes, I’m option-shift-baffled too…
    You can always edit the after effects shortcuts file, it’s a preference file in txt format.
  • Doug Nash
    January 22, 2008 at 6:27 pm
    Wow. That would be great. Any idea where to find that in the prefs, and how to properly change such without hosing the entire program???
  • Filip Vandueren
    January 22, 2008 at 6:41 pm
    on Mac you can find it at:
    yourusername/Library/Preferences/Adobe/After Effects/8.0/Adobe After Effects 8.0 Shortcuts
    I don’t know where it is located on Windows, but it probably has the same name, so you could search for it if you have a Winbox
    this is a normal text-file that’s designed to be altered in a texteditor.
    search for GoToTime and you will find:
    “GoToTime” = “(Option+Shift+J)”
    The syntax for changing it is pretty obvious.
    Incidentally Cmd+G is now:
    “Group” = “(Cmd+G)”
    It turns out that’s a new Group command that has to do with the new CS3 Shapes.
    If all of your keyboard shortcuts go wonky, just trash that file and a new one will be created with the defaults.
  • Doug Nash
    January 22, 2008 at 7:25 pm
    Sweet! Thanks! I’ll give that a shot.
