Activity › Forums › Avid Media Composer › Go to Previous Edit Command Question
Posted by Sandy Shapiro on April 13, 2012 at 2:47 pmWhy is it that when I Go to Previous Edit Command it takes me to the next edit point but goes into trim mode? Is there a way to turn this off and just have the play head go to the next edit?
Frederic Lumiere replied 14 years, 4 months ago 4 Members · 6 Replies -
Michael Hancock
April 13, 2012 at 2:48 pmRemap it to Fast Forward and Rewind. Then it will go to the next edit without activating trim.
Michael Hancock
Editor -
Frederic Lumiere
May 14, 2012 at 4:46 pmWhy is it that sometimes this works and sometimes, REWIND takes me back to the beginning of the timeline?
Michael Hancock
May 14, 2012 at 6:40 pmRewind goes to the previous common edit on all selected tracks. If you have a track selected that runs the entire length of your timeline, or is blank, it will go to the beginning of the sequence, or if you have a handful of tracks selected and there is no common edit point it will probably just go to the beginning of the timeline.
Michael Hancock
Editor
