Activity Forums Adobe Premiere Pro Go to next edit point
  • Go to next edit point
    Posted by Terry Lyons on September 29, 2011 at 11:56 pm
    OK, how in the heck did I turn this off? The Page Up and Page Down keys now go to the beginning of the first clip and the end of the last clip. I have 120 clips in-between that I want to access however. It was working normally but I must of turned it off somehow. I closed the program and restarted but is still working the same way. How do I get normal functionality back?
    Ben G unguren replied 14 years, 12 months ago 2 Members · 3 Replies
  • Ben G unguren
    September 30, 2011 at 1:09 am
    You probably have deactivated the tracks where the other clips are. Only the active (hilighted on the left side) tracks will respond to next-edit hotkeys. This also applies to things like inserting cuts at an edit (command+K).
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Terry Lyons
    September 30, 2011 at 1:41 am
    Yes, that did it! That’s hard to notice. Thanks!
  • Ben G unguren
    September 30, 2011 at 6:03 am
    No problem. FWIW, I have custom hotkeys set to select tracks: command+1 selects V1, command+2 is V2, etc. Likewise, opt+1 for A1, opt+2 for A2, etc. When I need to do a lot of jumping around the timeline, these hotkeys are quite useful, and a lot faster than mousing.
    Ben Unguren
