Activity Forums Apple Final Cut Pro Go forward 1 second
  • Go forward 1 second
    Posted by Julian Bowman on January 5, 2013 at 11:54 am
    is there really no shortcut for go forward 1 second? All I can find is 10 frames. What use is 10 frames? Especially when working in PAL, it isn’t any relevant number to frames per second or anything, just seems like an arbitrary number the picked because it was just different from FCP7.
    Why wouldn’t they have a shortcut for a sensible length? Some things about the execution of FCPX I simply do not get. For every time saving feature they have removed a time saving feature that makes everything take longer than it used to. Weird decisions at times.
    Cheers
    Dave Jenkins replied 13 years, 8 months ago 4 Members · 6 Replies
  • Paul Figgiani
    January 5, 2013 at 1:08 pm
    Use the period key (.) for seconds.
    So for a 1 second advance ” + 1 . ”
    Drop the period for frames …
    -paul.
  • Dave Jenkins
    January 6, 2013 at 12:54 am
    I think you need to add the shortcut Command P first.
    Dajen Productions, Santa Barbara, CA
    MacPro Two 2.66GHz Quad Core – AJA Kona LHe
    FCS 3 OS X 10.7.4
    FCP X, Adobe CS6, Logic Pro, Squeeze, Filemaker
  • Paul Figgiani
    January 6, 2013 at 2:39 am
    Dave said:
    “I think you need to add the shortcut Command P first.”
    You can just click in the Timeline or in the Timecode display area. Technically you are correct 😉
    -paul.
  • Bret Williams
    January 6, 2013 at 5:37 am
    Works like legacy. Type +1. Enter
  • Julian Bowman
    January 6, 2013 at 10:49 am
    Thanks all. Workaround I guess. Shift + -> is easier and not sure how a shortcut for go forward 10 frames is a better alternative to one for 1 second.
  • Dave Jenkins
    January 6, 2013 at 6:04 pm
    Your right, you only need Command P to go to a specific timecode.
    FCS 3 OS X 10.7.4
