Activity Forums Adobe After Effects gltiches with tinderbox 2 – lens blur
  • gltiches with tinderbox 2 – lens blur
    Posted by Scott G on May 17, 2006 at 9:00 am
    my tinderbox keeps going nuts, and every now and then (more often these days) when rendering, it will spaz out in the top half of the frame, and draw a lot of vertical bandy lines with strage halo effects and wacky colour. this is incredibly annoying, and it’s becoming difficult to get a render out without having to fix a hundred random frames. re-rendering, more often than not, fixes the problem frames but causes glitches on OTHEr random frames.
    any clues as to why this is happening?
    has anyone has this same problem?
    please help!
    thanks,
    scott.
    Rob@thefoundry replied 20 years, 4 months ago 2 Members · 2 Replies
  • Scott G
    May 17, 2006 at 9:01 am
    oh – i am using 6.5 on a pc. the guy with the mac has never ever experienced this problem before. the other pc guys says he’s had it once or twice in his life.
  • Rob@thefoundry
    May 18, 2006 at 2:03 pm
    Scott,
    This sounds like a unique problem, I have not come across this one before.
    However, I will dig through our archive and see if any of my colleagues had this problem previously.
    Does this happen only in T_Blur?
    Meanwhile, I would suggest that a fresh reinstall of the latest version of the plug-ins, in case the files have become corrupted.
    You can download Tinderbox 1 here:
    https://www.thefoundry.co.uk/pkg_downloads.aspx?ui=BEEF823D-BCFE-4E91-8CC9-0FBFFFB45D0A
    You will need to re-serialize the plug-ins with the original CD though.
    Please contact me if you have any questions support[at]thefoundry[dot]co[dot]uk.
    Regards,
    Rob
    Foundry Support
