Activity › Forums › Adobe After Effects › Glowing eyes like Stargate
  • Mike Clasby
    August 8, 2007 at 12:02 am
    If you could post a link, like this:
    https://www.youtube.com/watch?v=jxlF-iaZm6g
    that would be real helpful for us non-Stargate folks. I didn’t see any glowing eyes.
    Got link?
    Best movie for 2007 (so far):
    Once
    What? no SFX?
  • Mike Clasby
    August 8, 2007 at 12:04 am
  • David Franklin
    August 8, 2007 at 7:22 pm
    I agree with Yikesmikes. That tutorial will get you set up.
    And if you’re thinking “do I really have to track the footage?” sadly, even at a beginner level, the tracking is necessary.
    But if you follow the steps in that tutorial to get your face first tracked, then put in a separate comp, then reverse-tracked so that you can work stationary elements into your footage as is demonstrated, the eyes are going to be easy.
    Essentially, I would create a new adjustment layer, draw masks around the eyes, parent it back to your main layer, then experiment with the Effect > Stylize > Glow effect.
    You could also add an Effect > Color Correction > Exposure. Or Curves, or any number of color correction effects.
    Finally, I would also play around with the blending mode of the adjustment layer. Overlay, Soft Light, and Color Dodge may produce some interesting results.
    Hope this helps.
  • Alex Carr
    November 16, 2008 at 7:11 am
    I think i know what he is talking about, i am trying to find a tutorial for the same thing, myself.
    Here is a clip of what he is talking about.
