Activity › Forums › Adobe After Effects › glow outline
  • glow outline
    Posted by Aqeel Sami on June 21, 2010 at 8:59 pm
    i want to outline a country on a map and i want that outline to glow and become featherd for a while and then get back normal. i used stroke and glow but i couldn’t get the outcome i want.any help ? thanks alot.
    Todd Kopriva replied 16 years, 3 months ago 4 Members · 4 Replies
  • Michael Szalapski
    June 21, 2010 at 9:22 pm
    Can you describe what you tried or post a render or screenshot so we can see?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • David Johnson
    June 21, 2010 at 11:04 pm
    It sounds like you just want to animate the glow radius and/or intensity up and back down. You could also use a radial shadow and animate its softness and distance. There are lots of other ways to make things glow in AE, which gets back to Michael’s point that it depends on the look you’re going for.
  • Aqeel Sami
    June 22, 2010 at 10:18 am
    i want to show a map and there is ouline around a country border and i want that line to glow for seconds and return back normal. i did as David said it was ok but the glow online around the outside of the stroke and i want the glow to increase outside and inside of the stroke.
  • Todd Kopriva
    June 23, 2010 at 6:58 pm
    You can use the Inner Glow layer style to add a glow on the inside of a boundary.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
