Activity Forums Boris FX Sapphire Glow on black text
  • Glow on black text
    Posted by Morten Raarup on July 19, 2006 at 11:12 pm
    Why is it that I can’t get effect as Ray and Glow to work on at black text. It works fine if the text is
    whit or gray but if the test is full black it won’t work?
    Are ther a work around?
    Morten Raarup
    On Off Line Postproduction
    Copenhagen, Denmark
    Gary Oberbrunner replied 20 years, 2 months ago 2 Members · 1 Reply
  • Gary Oberbrunner
    July 20, 2006 at 1:34 pm
    Hi Morten.
    In that case turn up “Rays From Alpha” or “Glow From Alpha” and you’ll get what you want. With black text I also often use “Rays Under Source” or “Glow Under Source” to put the glow under/behind the source text; gives a really nice look.
    This works on the Sapphire2 for Avid version that you have, as well as the AE/FCP and Sapphire2 for Shake versions.
    — Gary
