Activity › Forums › Adobe After Effects › glow inside lamp
  • Chris Wood
    April 22, 2012 at 7:25 pm
    You could try creating the glow in C4D, which would make a realistic glow.
    Render out the .mov as an Alpha, then duplicate it for the reflection, adding a distort effect for the water?
  • Tudor “ted” jelescu
    April 22, 2012 at 11:01 pm
    I would go for AE- it seems to me that you have more options and control for glow (especially if you work in 32 bit). I would render out a pass of just the inside of the lamp from C4d though.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Victor Camacho guerrero
    April 23, 2012 at 10:53 am
    Hello everyone,
    after being between render times, I think it is better solution and faster going with the AE solution.
    The reasons:
    – After following this topic: https://forums.creativecow.net/thread/19/863440
    I realized how difficult ( and long) is getting right the glow trhough the paper in 3D.
    – Glow in Cinema has loads of limitations
    – Ae has way more options for creating glow.
    SOLUTION:
    – I did the lantern in 3d with a normal pass.
    – Using the amazing plugin Camera Tracker I put my lantern in 3d.
    – I duplicated the cube , using this position I created a light ( using mask and feather and glow effect) and add over the lantern using the right blending mode.
    – Because the wood cannot be totally affected by the light, I used a rotobrush on the wood part of the lantern, and I put this layer over the lantern. Making the light wrapped inside.
    – For the water, what i am going to use it is the same lantern, by applying distort effect such as same when you creathe ripples for fire and use the right blending mode over the water.I guess i will need again rotobrush and 3d tracking to place perfect the effect.
    I hope this helps to someone!!!
    Cheers
