Activity › Forums › Maxon Cinema 4D › Globe/Earth model
Globe/Earth model
Posted by Julia K on August 25, 2006 at 2:35 pmI know 3d cafe had globe/earth models but they are down for some reason. I know its easy to make one but before I start making it i was wondering if there are any free models available… since i’m pressed for time on this project.
Thank you.
Kevin Snyder replied 20 years ago 3 Members · 5 Replies -
Julia K
August 25, 2006 at 2:57 pmNevermind the above post… please ignore it
I do need help in creating clouds… earth was easy. but creating clouds proved to be slightly more difficult.
Thanks for all your help
Julia K
August 25, 2006 at 3:55 pmI have Cinema4d 9.6 and it comes with the sky plugin but I have no clue how to make it do what i want, I need to have clouds go around the earth globe…
Please help…
Amish Ed
August 25, 2006 at 4:52 pmWhat about taking your existing earth map, add a blank layer in Photoshop above the earth one. Then paint in your clouds on that empty layer (or layers if you want more depth), cloud filters are under filters>render>clouds. Probably need to make an alpha for that layer, dump the earth image, save it, and map it onto a sphere slightly larger than the earth one. I hope this in some way; but like I just posted down below, I know enough C4d to be dangerous.
Amish Ed
“Shoot ’em all and let the Editor sort ’em out!”Dual 2Ghz G5, 4GB, running 10.3.6 w/QT 6.5.2, Black Majic DeckLink, AE Pro 6.5 w/BCC and Invig. 3D, PS CS2, AI CS2, FCP HD
Julia K
August 25, 2006 at 5:14 pmI was wondering if there was a way to make the clouds have volume, so that when the camera goes through them, they behave as clouds would. The camera will zoom in to earth and the clouds will act as a transition to the next shot.
I was thinking of using the sky plugin or the Pyroclusters but I don’t know how to with both.
Thank you once again for your help
Kevin Snyder
August 25, 2006 at 11:53 pmYou can do it very nicely with just pyrocluster. If you have TP, you could make a sphere bigger than your earth model and have particles emit from the sphere with no speed on the particles. Add a little wind to move the clouds a bit.
KMS
