Activity › Forums › Avid Media Composer › globally remove ins and outs
  • globally remove ins and outs
    Posted by Rob Alexander on June 11, 2012 at 5:16 pm
    Hi All,
    Despite having cut on AVID for 18 years I know there are loads of shortcuts hidden in there that I don’t know, but is there one for this….
    I want to be able to select all the clips in a bin and then clear all of the marked in and out points so that I can make a timeline of the unedited clips to use as a source (virtual tape if you will). It was easy in FCP but I’ve never found a way to do it in media composer.
    Any suggestions?
    Michael Phillips replied 14 years, 3 months ago 4 Members · 4 Replies
  • Rob Alexander
    June 11, 2012 at 5:51 pm
    Ah… it’s so easy you’d never think of it!!
  • Michael Hancock
    June 11, 2012 at 5:52 pm
    Select all the clips in the bin, hit the Remove In/Out shortcut on your keyboard. You used to have to be in script view or another view (not basic – was it Text view?), but that might have changed in v6.x
    Michael Hancock
    Editor
  • Job Ter burg
    June 11, 2012 at 7:39 pm
    Been doing that since waaaaay before (the current) v6.
  • Michael Phillips
    June 11, 2012 at 9:26 pm
    You can also use AutoSequence which was designed for virtual reel creation. Selecting all clips and then AutoSequence will create a sequence where source timecode matches record side timecode. So if using TOD, there very well may be black gaps between clips. If you use the “option/ALT” key while selecting AutoSequence, it will create the same sequence with no gaps, (and no matching timecode between source/record). The AutoSequence process will also clear all marks in the process.
    Michael
    Michael Phillips
