Activity Forums Avid Media Composer Globally Remove effect
  • Globally Remove effect
    Posted by Greg Cohan on June 12, 2013 at 6:20 pm
    Is there a way to globally remove effects from a sequence?
    Tried
    Mark I/O
    Select track
    Remove Effect Fast Key
    But only removes clip you are parked on.
    Working on 6.5.2.1
    Shane Ross replied 13 years, 3 months ago 3 Members · 4 Replies
  • Glenn Sakatch
    June 12, 2013 at 8:33 pm
    not infront of my box, but can’t you draw a box to select all the clips in question and either remove effect or event just the delete button?
    Glenn
  • Shane Ross
    June 13, 2013 at 12:34 am
    I just tested it…why yes you can!
    This is akin to how you can add effects to clips globally. Lasso, or SELECT…then double click on the effect. It is applied to all selected.
    Nice!
    Shane
    Little Frog Post
  • Greg Cohan
    June 13, 2013 at 1:22 am
    Thanks that helps…. Ironically I guess I could have crossed the hall and asked you Shane 🙂
  • Shane Ross
    June 13, 2013 at 2:26 am
    Well Greg (who is my current boss), I didn’t know this, until now. I knew how to add effects to multiple clips (Titus told me). But I didn’t know how to remove them.
    Shane
    Little Frog Post
