Activity Forums Adobe Premiere Pro Global text changes using templates.
  • Global text changes using templates.
    Posted by Reuben Fink on January 17, 2013 at 12:59 am
    I’m coming from a FCP workflow where I would create a template in Motion for text (lower 3rds) that way if a client wanted to change the font or color of the font I could do this to the original template and all instances would update. Is there a way to do this in Premiere? Global changes to text that is. Thanks.
    – Rube
    OSX 10.8.2
    Equipment: 2.8 ghz 8 core Intal Mac Pro 3,1 Early 2008, 20 gig of ram
    Aps: CS6 Production Premium, FCP Suite, Avid Media Composer
    Alex Udell replied 13 years, 7 months ago 3 Members · 2 Replies
  • Victor Perez
    January 17, 2013 at 5:39 pm
    I use templates for lower thirds using the title tool.
    Type your text in Title Tool
    With the Title Tool open hit “Command j” to open the Templates window
    At the upper right of the Templates window click the icon and select “Import Current Title as Template”
    rename your title and it should appear in the Templates window under User Templates.
    hope that helps
    Victor
    editvictor.com
    http://www.hbhm.tv
    http://www.itvisus.com
  • Alex Udell
    January 18, 2013 at 1:06 am
    That addresses some of what you want…but not all of it….
    you are taking about propagating style changes across multiple existing titles….
    particularly with font style changes, this can get tricky…
    Might want to consider doing
    the text part of titles as a multi layer photoshop doc….
    then using the various layers as the text portion of your titles in Ppro…
    that way if you decide to change fonts…
    you can multi-select layers in Photoshop….
    change the font…
    resave…
    then it will all be updated in PPro….
    Alex Udell
    Editing, Motion Graphics, and Visual FX
