Activity Forums Maxon Cinema 4D Global Local movement
  • Global Local movement
    Posted by Chris Smith on June 30, 2006 at 10:24 pm
    I manage to know C4D pretty in-depth but apparently I’ve missed probably the simplest thing yet. So the stupidest question ever:
    How can I use the move tool in global mode as opposed to local mode? Meaning, I have a cube and rotate it “cock-eyed” I want to leave it like that but move it straight up in Y. How can I switch the axis handles to show global coordinates instead of the “Cock-eyed” local coords?
    Chris Smith
    https://www.sugarfilmproduction.com
    Chris Smith replied 20 years, 2 months ago 4 Members · 4 Replies
  • Justincredible
    June 30, 2006 at 11:11 pm
    Hi Chris,
    In the default Cinema 4D layout, just to the right of the Move/Rotate/Scale tools, there are X,Y,Z axis-lock toggles, and a Global/Object coordinate toggle button (icon is an Axis below and to the left of a Cube, or a Globe for Object and Global, respectively).
    With the Move tool active, if you turn off X and Z in the axis toggles, and click the Object/Global toggle, you should be able to just move your object in the Global Y space.
    If you have changed your layout, you can find them under the “Tools” menu, or use the shortcut keys. ‘X’,’Y’,’Z’ toggle the axis-locks, and ‘W’ toggles Global/Object coordinates.
    Hope this helps!
    -Justin
    Justin Faberlle
    3D Animator
    New York, NY
  • Adam Trachtenberg
    July 1, 2006 at 2:47 am
    Yep, you can do that numerically throught the coordinates manager, but unfortunately there’s no way to get a normalized axis directly on the object. If you want/need to do that you can create a null and drop your object inside it. Then move the null instead of the object.
  • Alan Lacey
    July 1, 2006 at 6:07 am
    Yes, it’s weird, you can do it at the sub-object level in the tools attributes\modelling axis. But not at the object level.
    Alan
  • Chris Smith
    July 3, 2006 at 1:25 am
    Thanks Guys. That works. Would be nice if hitting the local/global button would change the Axis handles to reflect the new coord system though :-/
    Chris Smith
