Activity › Forums › Maxon Cinema 4D › Global illumination question
Posted by Emmet Reddy on October 23, 2009 at 9:36 amI have a scene created i have used global illumination, when i render a single frame its crisp and clear but if i animate it, it goes all flickery.
Any ideas?
Thanks EmmetEmmet Reddy replied 16 years, 11 months ago 3 Members · 4 Replies -
Randy Johnson
October 23, 2009 at 11:03 amwhat version of C4D are you using? This has been a serious issue before r11. There are solutions but generally require huge render times.
/Randy -
Emmet Reddy
October 23, 2009 at 12:26 pmits v10 but i have access to another system which has v11 but i would rather keep it on my system if i could, i know it will take a while to render i will leave it over the weekend if i could get it to work.
would changing global illumination to camera animation make any difference?
thanks emmet -
Adam Trachtenberg
October 23, 2009 at 3:44 pmDo you have animated objects in the scene, or just an animated camera? If it’s just the camera you should select “camera animation” from the drop down box at the top of the GI dialogue.
In any case, it’s hard to eliminate flicker. Stochastic mode will eliminate it altogether, but it can be grainy and/or painfully slow.
If you don’t use stochastic you have to crank up the quality and min/max settings which again makes it pretty slow.
Emmet Reddy
October 23, 2009 at 4:30 pmcheers i will give it a go back in 2 days fingers crossed
Thanks Emmet
