Activity Forums Maxon Cinema 4D Global Illumination Problem
  • Global Illumination Problem
    Posted by Ej Hassenfratz on February 29, 2008 at 9:30 pm
    I have a scene with a lot of extruded objects. I have instances of these objects to make things easier as I have over 100 of these objects.
    Im working at 1280×720, and when I switch on the GI or even AO, it crashes when it goes to render the scene.
    What am I doing wrong???
    ej.hassenfratz
    senior.graphic.designer
    wjla-nc8/eyedesyn.com
    washington.dc
    Adam Trachtenberg replied 18 years, 6 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    March 1, 2008 at 6:44 am
    You’re probably running out of memory. Unless your extrusions are animated, I’d convert them to polygons before instancing and see if that helps. Also check your scene poly count and see if you can’t cut it down somehow.
    AdamT
    Cinema 4DXL8 Bodypaint
    *Remember: Tues. is national Shoe Day. Wear shoes to show your support for bimetalism and the designated hitter rule!*
