Activity Forums Maxon Cinema 4D Global Illumination & Net Rendering
  • Global Illumination & Net Rendering
    Posted by Justin Puda on March 9, 2009 at 4:53 am
    Hello,
    I have just set up a net render network in our office. I have been working with scenes using GI and have noticed there is a net render setting in the GI animation mode. How does this work? Does it speed up rendering times? I have been reading online about saving out a IR cache file and uploading it to the server. Can’t quite figure out how to accomplish this. Any ideas?
    Justin
    Gabe Juhnke replied 14 years, 10 months ago 2 Members · 1 Reply
  • Gabe Juhnke
    October 31, 2011 at 8:21 pm
    Saving the Irradiance Cache you’d think would work. My understanding is that if you render your GI pre-pass on a single machine, then send that file to the server, you should be able to render via the network.
    However, I’m having several problems with this myself. First- I have to send the GI prepass files in the Illum folder manually. “Save Project” does not transfer my GI pre-pass to the server automatically. Second- After I send the GI pre-pass to the server, Net-render only renders to a single computer (the server). It doesn’t distribute the GI pre-pass to all of the other computers on the server.
    If I figure this out, I’ll let you know. In the meantime… theoretically, this should work. Also, my understanding is that it doesn’t matter what GI Mode you are in. I don’t believe it needs to be on IR + QMC (Net Render) in order to render GI on the server.
    Hope this helps ya!
    -Gabe
