Activity › Forums › Maxon Cinema 4D › Global Illumination Issue – Big stains and splotches
  • Global Illumination Issue – Big stains and splotches
    Posted by Corrado Carlevaro on May 30, 2013 at 7:26 am
    I’ve never had GI issues but now I’m rendering a VERY simple scene (cloned white cubes with a bend deformer, one light, one sky, IR+QMC (full animation) with standard settings) I’ve big brown, black stains on some faces of the cubes. I’ve tried to switch off all other elements in the scene (floor, background), to change field of view of the camera (pretty wide), to cut up the render in blocks, but nothing to do. When I render a single frame there are no artifacts at all.
    Thanks for any help
    Corrado Carlevaro
    Corrado Carlevaro replied 13 years, 3 months ago 4 Members · 20 Replies
  • 20 Replies
  • Adam Trachtenberg
    May 30, 2013 at 2:25 pm
    I would check your GI cache settings … make sure you aren’t using an old or partial GI cache file.
  • Corrado Carlevaro
    May 30, 2013 at 2:39 pm
    Thank you for your reply,
    but I’ve also unchecked Auto Load and Auto Save from Cache settings, if this is what you mean.
    Tried almost every setting.
    Frame attached
    Corrado
  • Adam Trachtenberg
    May 30, 2013 at 5:12 pm
    Can you post the scene file? Hard to say otherwise.
  • Corrado Carlevaro
    May 30, 2013 at 5:46 pm
    Of course, very kind of you.
    One doubt: has animation, Xpresso or stuff like that, something to do when it comes to rendering or is, as I suppose, just a matter of geometry “as you see it”?
    6086_worm.c4d.zip
    Corrado
  • Adam Trachtenberg
    May 30, 2013 at 10:44 pm
    Hmm! I’ve looked at it and tried a number of different settings, but nothing seems to eliminate the problem.
  • Brian Jones
    May 31, 2013 at 3:29 am
    render only 10 frames (48 to 58) and it goes away. Remove the lights and it goes away. Uncheck ‘GI Illumination’ in the two light’s General tab and it goes away. No idea why though, maybe send it to Support, they might know.
  • Adam Trachtenberg
    May 31, 2013 at 3:39 am
    Yeah, I noticed that it depends a whole lot on the number of frames rendered. First 15, 35, or 50 frames is fine. Render from start to finish and it’s a mess.
  • Corrado Carlevaro
    May 31, 2013 at 6:19 am
    Thank you Adam and Brian, so it’s happening on your machines too.
    Me too I noticed it depends on the lenght, but I really don’t know what to do, it’s a very basic setup. I saw in a different forum a frame with the same kind of brownish stains but the guy was rendering an animation with Still Frame settings.
    I rebuilt the whole setup from scratches but it’s happening again.
    Corrado
  • Adam Trachtenberg
    May 31, 2013 at 2:55 pm
    I agree with Brian — send it to Maxon tech support and see if they can sort it out (or report it to the developers if it’s a bug).
  • Corrado Carlevaro
    June 1, 2013 at 4:47 pm
    I’ll try, frustrating, thank you anyway
    Corrado
