Activity Forums Adobe After Effects Global frame rate change for entire project?
  • Global frame rate change for entire project?
    Posted by Steven J casey on April 2, 2016 at 6:12 am
    I’m working on a project with tons of comps. Is there a global command to change the frame rate instead of going into every comp manually? This would be a huge time saver, I just don’t see where to do it.
    thanks,
    steven
    Pierpaolo Ferlaino replied 10 years, 5 months ago 2 Members · 3 Replies
  • Pierpaolo Ferlaino
    April 2, 2016 at 8:58 am
    You can use rd comp setter to batch change composition settings…
  • Steven J casey
    April 2, 2016 at 4:42 pm
    Thanks for the quick reply. I tried the script and unfortunately it doesn’t seem to work. When applied, AE seems to run for a few seconds then goes into “not responding” mode and is locked up. Any other options?
    April 2, 2016 at 11:10 pm
    I use this script on large projects with no problem… However I’m still on CC2014… Unfortunately I don’t know other methods to batch change frame rates for after effects compositions… Maybe someone else can help….
