Activity Forums Adobe After Effects Global Changes to Mask keyframes?
  • Global Changes to Mask keyframes?
    Posted by Eric Goldstein on March 28, 2006 at 5:27 pm
    Does anyone know how or if it is possible to make global changes to a series of key frames on a layer?
    I have a mask from another layer. That layer has different dimensions. I’d like to apply a scale and rotation
    to all the mask shape key frames on the new layer – globally.
    Anyone have any ideas?
    Eric Goldstein
    Giraffe Film Company
    Los Angeles
    eric@giraffefilm.com
    Steve Roberts replied 20 years, 5 months ago 3 Members · 2 Replies
  • Mylenium
    March 28, 2006 at 5:37 pm
    No, not really. Masks are treated relative to the layer size, not in world coordinates and you can’t access any of their parameters directly. You really can only solve this the hard way by manually scaling and adjusting the masks at every keyframe.
    Mylenium
    [Pour Myl
  • Steve Roberts
    I recommend you copy and paste the mask to a new solid, then use that solid as a track matte for the layer that you were masking before. Then you can change the Scale and Rotation properties of the solid itself.
    … since you cannot scale or rotate a group of mask shape keyframes at once.
    … if I understand your meaning.
