Activity Forums Apple Final Cut Pro Legacy Global Audio Pan Change?
  • Global Audio Pan Change?
    Posted by Joe Zabrosky on October 7, 2014 at 3:59 pm
    Is there a way to globally change your left and right audio channel pan in a two hour project. I’m presently manually changing every clip. Doesn’t hurt to ask.
    Thanks, joe
    joseph zabrosky
    Mark Suszko replied 11 years, 11 months ago 2 Members · 3 Replies
  • Mark Suszko
    October 7, 2014 at 4:05 pm
    Fix the pan on the first clip. copy the clip, highlight ll the other audio clips, right click to find “paste attributes” and select pan from there.
  • Joe Zabrosky
    October 7, 2014 at 7:04 pm
    THANK YOU SO MUCH!!!!!!!!!!!!!!! I’m suppose to know how to do that but forgot. Thanks again!
    joseph zabrosky
  • Mark Suszko
    October 7, 2014 at 8:02 pm
    Just help someone else out when you know you know the answer, sometime.
