Activity › Forums › Adobe Premiere Pro › Global audio noise reduction workflow
  • Global audio noise reduction workflow
    Posted by Steve Brame on November 10, 2012 at 10:13 pm
    Certainly a very common type of project is where you have cuts from many different interviews that were shot in different locations. I’ve become quite adept at removing ambient noise from A/C and such with Audition’s Noise Reduction Process, but was wondering if there was a better workflow than the one we use. Generally we place the clips’ audio from a single person’s interview on their own track. After the project is edited visually, I save each track out as a WAV to put into Audition for noise reduction. I do this even if all of the interviews were shot in the same room. I’ve found that it’s dangerous to use one person’s noise print onto another person’s noise reduction process, hence why I separate the audio to different tracks. I then save the cleaned audio back to the same WAV file, and place it on a track adjacent to the original audio’s track, also muting the original.
    I’d love to hear other workflows in use. Something tells me that mine is a bit convoluted.
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
    Angelo Lorenzo replied 13 years, 10 months ago 2 Members · 1 Reply
  • Angelo Lorenzo
    November 11, 2012 at 10:09 pm
    I use the same process. Regardless of other workflow issues, you’ll be limited to using a noise print per microphone. A noise print is just that, a print. Each microphone, even of the same model will have different variations in frequency response, gain level, and distance/direction from noise source.
    I’m not sure if there is an easier way… it’s just a little brute work.
    Angelo Lorenzo
    Love my answer? Do me a huge favor and check out my Kickstarter project The Librarian, starring Jennie Garth of Beverly Hills 90210.
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
