Activity › Forums › Apple Final Cut Pro Legacy › Glitchy Video on Export from Final Cut
Posted by Errol Lazare on June 20, 2012 at 6:21 amI am experiencing a glitch when I export from final cut using Export to Quicktime Movie.
Basically after every edit point there is a mosaic square pixelated glitch that appears.I am on a Mac Pro 8 Core 2.8 GHz processor. My editing / scratch drive is 2x 1TB stripped drives.
Has anyone experienced this problem before?Thanks!
Errol X. Lazare
EXL Films
http://www.exlfilms.comJacob Brown replied 10 years, 6 months ago 6 Members · 5 Replies -
Shane Ross
June 20, 2012 at 6:53 amWhat is the format of the footage in your sequence? What codec?
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Grant Strac
June 20, 2012 at 8:16 amHey,
Yes I have had many problems similar to what you are having. In my experience I have found that my system was being taxed out and this is why glitches are happening. I am sure you will know most of my following advice but to cover all bases I will lay them all out. First you should never do anything on your system while your machine is exporting an MOV from final cut. My system has 22gb of ram and when I do export this way I still don’t let it do anything but focus on that. Next I would shut down completely, not restart it does not fully close out the machine. I found after editing for hour I would not have issues but four hours or more sometimes this happened. Close out all programs but what you are using.
If the problem persists I would like to offer a work flow change. After having problems like this I now never export self contained mov for final print of previews. I always export from final cut timeline to compressor and set my settings there. I have not used self contained export in years because it does not dedicate ram and processor usage directly to that task. Compressor does dedicate a certain amount of system functions to the encoding task and will not waver unless you seriously tax out the machine like do motion graphics while it is encoding with compressor. If I am under a time crunch and need to encode quickly I do export in FInal Cut but deselect the “self contained” and then import this non-self contained file into compressor. Self contained means that all the footage and information is embedded into the video and non self contained basically makes the timeline one flattened product. It is only a reference file for final cut to your project file locations.
Sorry for the addition information if it bothers you I am certified trainer so I like to cover all bases.
In you problem after trying to calm your system down if the export from final cut still gives glitches I will say with 97% confidence that if you export using compressor this problem will disappear. If it still happens then your problem is with your original media but this sounds like that is not the case but it’s always good to find that file where it glitches on and reveal in finder to preview using quicktime just to be sure. When these problems arise I always suggest to look at all avenues just to be sure.
Compressor is a POWERFUL program and with all of FCS’s roundtripping abilities it’s best to go ahead and use the corresponding program with the tasks you need to finish. Also using compressor will most likely yield quicker encodes than doing it from Final Cut.
I hope this helps
Grant Strac
Apple Master Pro Certified FSC2
Apple Trainer Certified FCP6
Apple FCS Optimization Certified -
Rafael Amador
June 20, 2012 at 12:34 pmYeap.
That smells to some GOP based codec.
Do you have the same glitches in your time-line.
rafael -
Tony Brittan
June 20, 2012 at 3:04 pmThat was my first question! Betting it’s some sort of h.264 or something.
Posted from iPad, please excuse typos!
Jacob Brown
March 13, 2016 at 10:52 pmdid you ever resolve this? i’m having the same problem both in timeline and export. only in FCPX not in resolve. on a maxed out brand new iMac
