Activity › Forums › Adobe Premiere Pro › Glitchy Quicktime Screen Recordings in Premiere
  • Glitchy Quicktime Screen Recordings in Premiere
    Posted by Dan Hirshon on October 2, 2020 at 10:31 pm
    I’m having issues trying to play quicktime screen recordings in Premiere. It either skips, or glitches, or has green showing up screen):
    https://www.youtube.com/watch?v=bVR8fYOEbkY&feature=youtu.be
    I’VE TRIED:
    -transcoding it to Prores in Media Encoder
    -Changing the Audio Hardware Default Input setting to “no input”
    -Clearing my cache and preview files
    -restarting premiere and my computer multiple times
    -recording multiple screen recordings to see if anything changes
    -changing the MPEG Source Settings to “smooth video motion”
    MY CURRENT COMPUTER SETTINGS ARE:
    Mac Catalina 10.15.7 (latest update)
    MacBook Pro Retina
    Processor: 2.5 GHz Quad Core Intel Core i7
    Memory 16GB
    Graphics: AMD Radeon R9 M370X 2GB
    Intel Iris Pro 1526 MB
    Premiere Pro 2020 (14.4.0) (all the Adobe apps I have are up to date)
    Quicktime 10.5 (1015.2.1)
    HERE IS WHAT COMES UP WHEN I CHECK THE CLIP PROPERTIES IN PREMIERE:
    Type: QuickTime Movie
    File Size: 231.30 MB
    Image Size: 1920 x 1080
    Frame Rate: 23.976
    Source Audio Format: 48000 Hz – 16-bit – Stereo
    Project Audio Format: 48000 Hz – 32 bit floating point – Stereo
    Total Duration: 00:00:28:05
    Pixel Aspect Ratio: 1.0
    Alpha: None
    Color Space: Rec. 709
    Color Space Override: Off
    Input LUT: None
    Created with: Adobe Adobe Media Encoder 2020.0 (Macintosh)
    QuickTime Details:
    Movie contains 1 video track(s), 1 audio track(s), 0 closed caption track(s), and 1 timecode track(s).
    Video:
    There are 677 frames with a duration of 1001/24000ths.
    Video track 1:
    Duration is 0:00:28:05
    Average frame rate is 23.98 fps
    Video track 1 contains 1 type(s) of video data:
    Video data block #1:
    Frame Size = 1920 x 1080
    Compressor = Apple ProRes 422 LT
    Quality = Most (5.00)
    Audio:
    Audio track 1 contains 1 type(s) of audio data:
    Audio data block #1:
    Format = 16 bit – Stereo
    Rate = 48000 Hz
    Compressor = sowt
    Timecode:
    Timecode track 1 contains 1 type(s) of data:
    Timecode data block #1:
    Start Time = 00:01:06:10
    Reel name =
    Any ideas what I can do?
    Thanks in advance for your help!
    Dan
    Dan Hirshon replied 5 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
