Activity Forums Adobe After Effects Glitchy Loop?
  • Glitchy Loop?
    Posted by Robin Lewis on September 28, 2010 at 11:38 pm
    I have been working on a project which requires me to create a walk cycle for an ant.
    I created the body and to animate the legs I made them in 2 sections. I then placed the anchor points on the joints and parented them where appropriate.
    Anyway I now have 3 legs that move as they should. However to repeat the movement I used a loop with the script:
    loopOut(type = “cycle”)
    This script works fine for most of the animation however occasionally when scrubbing through the walk cycle legs disappear and jump forward in the animation. For some reason some legs are worse than others.
    I can not understand why this is happening. I have never seen this before and thought the script was ok (I am new to scripting sorry!).
    Any suggestions for causes/solutions to this problem would be great!
    Thanks in advance for any suggestions,
    Rob
    Robin Lewis replied 15 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
