Activity Forums VEGAS Pro Glitchy audio in Vegas 12.0
  • Glitchy audio in Vegas 12.0
    Posted by Hsu Chaw-bin on October 4, 2012 at 10:42 am
    As said on topic, after I got Vegas 12, it’s nice, however I encountered a few issues.
    Such as, the audio is quite glitchy when there are multiple audio tracks.
    So far my project veg file contains 31 audio tracks, the sound jumps constantly when I play it back or scrolling down/up while playing back.
    The rendered mp3/wav doesn’t have that problem.
    The temporarily way I fix it is go to option and change the audio device and change it back.
    ASIO doesn’t help either.
    So yeah, that kinda has been bothering me, especially when I’m making remixes/music.
    Also, sometimes I click on play it’ll hang for a few seconds and then play.
    The hang I mean it just froze, like, not anything like ‘not responding’, it just simply hangs, I couldn’t press any buttons but when I hover to the medias the yellow outline does react.
    Any idea?
    Hsu Chaw-bin replied 13 years, 11 months ago 3 Members · 15 Replies
  • 15 Replies
  • Hsu Chaw-bin
    October 4, 2012 at 10:46 am
    Computer Spec just in case.
    Operating System Microsoft Windows 7 Ultimate 64bit
    CPU Type DualCore Intel Core i5 430M, 2533 MHz (19 x 133)
    System Memory 7990 MB (DDR3-1066 DDR3 SDRAM)
    Audio Adapter IDT 92HD81B1X @ Intel Ibex Peak PCH – High Definition Audio Controller [B-2]
  • Nigel O’neill
    October 4, 2012 at 12:31 pm
    [Hsu Chaw-Bin] “So far my project veg file contains 31 audio tracks, the sound jumps constantly when I play it back or scrolling “
    That’s quite a lot of tracks. Does it do it in SVP11 as well?
  • Hsu Chaw-bin
    October 4, 2012 at 12:33 pm
    No, not as much as Vegas 12 does.
    And 30+ audio tracks is nothing, my other project involves 100+ tracks and it doesn’t lag that much (and it was in Vegas 10)
  • Nigel O’neill
    October 4, 2012 at 12:42 pm
    What sometimes helped me in SVP 11 was to disable track buffering under Options > Preferences > Audio Device > remove tick from Enable Track Buffering. I
    t is not recommended to disable it, but if it cures your problem, you may need a better audio device such as an M-Audio Firewire 410.
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 11 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Hsu Chaw-bin
    October 4, 2012 at 1:04 pm
    That doesn’t really help, it kinda makes it worse sadly.
  • Nigel O’neill
    October 4, 2012 at 1:30 pm
    [Hsu Chaw-Bin] “That doesn’t really help, it kinda makes it worse sadly.”
    In that case, reenable track buffering, and on the same Audio Device tab increase the playback buffering (seconds) slider
  • Hsu Chaw-bin
    October 4, 2012 at 1:42 pm
    I did try that, it helps a little bit, but still constantly jumping after a few seconds.
  • Dave Haynie
    October 4, 2012 at 5:56 pm
    Hey… I have some projects from Vegas 11 of similar complexity. I’ll give it a try on my system when I get a chance. I never had glitches on 20-30 track projects in Vegas 11. These are audio mix project, all tracks in 96kHz/24-bit on a single 7200rpm SATA drive, mixed down to stereo for monitoring, a few dozen plug-ins active as well.
    -Dave
  • Nigel O’neill
    October 5, 2012 at 3:37 am
    [Dave Haynie] ” I have some projects from Vegas 11 of similar complexity”
    I would suspect the audio device. Increasing the buffer has had a positive but minimal improvement in Chaw-Bin’s case. He does not appear to be using a dedicated or high end audio device.
    When I reported similar problems with squirrely sound, John Rofrano suggested I had a deficient sound device (which is the case) 🙂
  • Dave Haynie
    October 5, 2012 at 6:31 am
    Could be the sound output device… but that still doesn’t explain any difference between Vegas 11 and Vegas 12. Also, for a mixdown, the stress isn’t really all that much on the card itself. Vegas is fetching all 20 or 30 or whatever tracks from HDD, applying FX, mixing to Stereo, etc… all in INTERNAL buffers, before the sound card is even involved. If he’s doing output to a multichannel device, of course, that’s very different.
    -Dave
