Activity › Forums › Apple Final Cut Pro Legacy › Glitchy Audio FCP 4.5 Dual 2 G5
  • Glitchy Audio FCP 4.5 Dual 2 G5
    Posted by Keith Golinski on April 26, 2005 at 12:37 pm
    I have been having problems with my audio tracks making popping noises that don’t show up on the audio waveform and that were brought in clean. When I create a new sequence to switch projects from 16:9 to 4:3, I select the sequence from the browser and drag it to a new timeline to make it full screen 4:3, this is when I get the audio problems. It also happens if I copy the entire timeline to a new timeline. The Audio pops are not in the original sequence but always show up when I copy to a new sequence. I have also made sure that my bit rates are the same for the both the original audio and the copied audio.
    The other problem I have been having is exporting Quicktime Movies Self-Contained I randomly get complete audio drop-outs in the exported pieces. With-out changing any settings I will have to re-export two or three times until the drop-outs magically disappear.
    I have been a FCP user since version 2 so glitches are nothing new but are becoming increasingly tiresome.
    Any thoughts or suggestions would be helpful.
    Thank you for your time.
    Keith Golinski
    Keith Golinski replied 21 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
