Activity › Forums › Adobe After Effects › Glitching Text Out Animation
  • Joseph W. bourke
    November 19, 2012 at 4:02 pm
    It looks to me as if it might be Twitch, from Video Copilot. It’s possible that it’s an AE text preset, but I don’t think so. If you browse the presets in Adobe Bride, you can look over animated thumbnails of them to see if there’s one which fits your needs.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Bryan Cheney
    November 19, 2012 at 4:06 pm
    I’ve looked through all the presets and there is nothing similar to that animation. I was thinking it might be from the Twitch software based on previews I’ve seen but I wasn’t sure. Thanks for the help!
  • John Cuevas
    November 19, 2012 at 4:24 pm
    If you do search for “bad” in your presets search box you will cum up with 3 BadTV presets you can apply to text, that will probably do the trick.
    Or take a look at this thread. I linked to the AESCripts “BadTV” plugin and linked to a project I created that recreates a portion of the BADTV look.
    https://forums.creativecow.net/readpost/202/896083
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Bryan Cheney
    November 19, 2012 at 5:28 pm
    I found the three BadTV presets before and BadTV 2 was closest to what I was looking for, however I was not able to get it to work exactly like I wanted to. I’ll have to go back and work with it and see what I can do. Much appreciated!
  • Roland R. kahlenberg
    November 20, 2012 at 3:00 am
    There are a couple of Twitch Expression on the following link –
    https://evanabrams.com/category/tutorials/
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects ACE/ACI (version 7)
  • Bryan Cheney
    November 20, 2012 at 3:26 am
    Exactly what I’m looking for! Many thanks Roland!
    November 20, 2012 at 7:25 pm
    You’re most welcome Bryan. FWIW, if folks here are on Facebook, you’ll receive frequent updates and links from the AE Team via the official Adobe AE page; which was were I found out about this link.
    You may also want to look at using AE’s Motion Sketch to achieve similar but more controlled movement.
    Cheers
    RoRK
