Activity Forums Adobe Premiere Pro Glitching Frames
  • Glitching Frames
    Posted by Jonathan Reed on January 23, 2021 at 3:25 pm
    Hello everyone, I hope you all are doing well, staying healthy.
    So i’m having issues with some footage. I’ve included a link of the clips that are doing this as visual reference. I’m not sure what’s happening or why. The kids turning quickly is a hit or miss when I export it, but all the other clips with the “glitching” or “ghosting” effect happen every time. Let me post some specs.
    Sequence is 7680×4320 (1.0) 23.97 fps 4800 Hz
    1st Clip: 7680×4320 (1.0) 25 fps
    2nd Clip: 7680×4320 (1.0) 25 fps
    3rd Clip: 7680×4320 (1.0) 23.97 FPS 4800 Hz (which I never have issues with)/ Scale: 132
    4th Clip: 7680×4320 (1.0) 25 fps
    5th Clip: 7680×4320 (1.0) 25 fps/ Scale: 189
    6th Clip: 7680×4320 (1.0) 24.01 FPS 4800 Hz/ Scale: 125 to 300 (doesn’t make any difference)
    7th – 10th Clip ^^^^
    I want to say that the issue is the FPS, but other clips aren’t having the same issue and they have 30fps, 25fps, and 24.01fps. A common thread is that all of these have pans. I’m not noticing this so much on any push’s.
    https://youtu.be/CjM7CXXV9G0
    I would greatly appreciate any advice on how to solve this problem.
    Thank You
    Jonathan J.R. Reed.
    Jonathan Reed replied 5 years, 7 months ago 2 Members · 3 Replies
  • Todd Perchert
    January 23, 2021 at 6:08 pm
    Your FPS is most likely your problem. What are your sequence settings and export settings?
    You are mixing a number of different frame rates – that don’t necessarily work well together – within one sequence.
  • Jonathan Reed
    January 23, 2021 at 8:19 pm
    Would transcoding the videos to the same FPS help or will that just maintain the problem?
    I know working with the same fps is the ideal goal, however, the video i have now ranges from 23.97, 24.01, 25, and 30FPS
    My sequence settings have my FPS at 23.97 export is the same.
  • Jonathan Reed
    January 23, 2021 at 11:10 pm
    I exported the final clip, of the man running to 23.976, I then put it in a sequence 23.976fps. The scale 100 works fine enough, scale 300 is glitchy as all hell.
