Activity Forums Apple Final Cut Pro Legacy Glitches when exporting movies from FCP
  • Glitches when exporting movies from FCP
    Posted by Mark Rodway on February 15, 2008 at 10:06 pm
    This is an issue that’s beginning to aggravate me somewhat as it’s quite a timewaster. I’ve noticed when exporting movies recently from FCP that I’m getting more and more ‘glitches’.
    I first noticed it when exporting a ‘legacy’ project from V5.1.4 times (approx. 12 mins very quick cut). This project had been media managed and archived etc. so I put it down to the age of the project and the fact that it had been so ‘processed’.
    However it’s become more of a frequent occurrence.
    The ‘glitches’ are intermittent and render the movie enough times and you get a pass when none are present. They usually take the form of a horizontal line approx. 10+pixels high and multicoloured (bright greens / magentas etc.). I’m suspecting that it’s just some minor file corruption (I say ‘just’ lightly).
    I’m running OS X 10.4.11 – FCP 6.0.2.
    Any suggestions or thoughts would be quite welcome.
    Many thanks..
    Mark
    Mark Rodway replied 18 years, 6 months ago 2 Members · 6 Replies
  • Russell Lasson
    February 15, 2008 at 11:28 pm
    First, I would dump your preferences.
    Can you tell us what codec you’re editing in? What are you exporting to?
    -Russ
    Russell Lasson
    Kaleidoscope Pictures
    Provo, UT
  • Mark Rodway
    February 16, 2008 at 10:18 am
    Russell,
    Cheers for your reply. I have had a number of ‘preference dumps’ in this time – but my settings have been :-
    The original timeline was DV PAL and had corruptions exporting either as a straight FCP ‘export as quicktime’ from the timeline or via compressor as an MPEG2 for DVD. It did eventually work but only after a number of attempts at getting a clean movie.
    The latest was a 1080 pro res HQ timeline and had the same issue as a straight export as quicktime and an attempt at 10bit uncompressed via quicktime conversion.
    Mark
  • Russell Lasson
    February 20, 2008 at 10:32 pm
    Strange. Have you added extra RAM to your computer? It’s possible that that could be causing the problem.
    -Russ
    Russell Lasson
    Provo, UT
  • Mark Rodway
    February 20, 2008 at 11:45 pm
    Russ,
    Hmmmmmmmmm………….. That’s a sharp insight……
    Yes, we have added additional RAM in recent months. We’ve added an additional 4x2GB crucial RAM.
    What effect might this be having – and what’s my solution.
    Many thanks for taking time to work on this issue with me.
    Mark
  • Russell Lasson
    February 22, 2008 at 5:53 pm
    Sometimes bad RAM can make a system to really strange things. Crucial’s a good company, but if you keep having the problem, try pulling out the RAM to test if the problem still exists.
    -Russ
    Russell Lasson
    Provo, UT
  • Mark Rodway
    March 3, 2008 at 10:02 am
    Russ,
    Had an opportunity to test the RAM with this project on Friday. Have been on other projects until now.
    Render 1 – Both old and new (crucial) RAM – very occasional glitches
    Render 2 – New (crucial) RAM only – very occasional glitches
    Render 3 – Old RAM only – glitch free – Crucial RAM goes back today for replacement…..
    Thanks for the heads up on that one Russell – the errors were so minor and infrequent, but on fairly longform (12minutes+) projects – they were causing me a real headache. I don’t think that I would have reached a RAM conclusion if it wasn’t for your steer.
    Great result – many thanks.
    Mark
