Activity Forums Apple Final Cut Pro Legacy Glitch occurs after every Transition
  • Glitch occurs after every Transition
    Posted by Matt Gussin on March 15, 2011 at 1:45 pm
    Hey, I am doing some work in Final Cut Pro and whenever i apply any kind of transition (fade, wipe etc) a glitch occurs on the last frame of the transition; what happens is that the frame seems to jump so for example when someone is speaking and waving his arm, you will see the person waving their arm again – if that makes sense – so basically, the frame jumps which makes it look a lot less professional..
    Any help please? – i have searched the forums but could not find any answers?
    Michael Kammes replied 15 years, 6 months ago 2 Members · 1 Reply
  • Michael Kammes
    March 15, 2011 at 4:33 pm
    What kind of footage are you transitioning to and from, and what are your timeline settings? Are you in Safe or Unlimited? Are you rendering the effect?
    I am assuming that you have plenty of heads and tails for the transition? Try taking 2 longer shots, and trimming a bunch of the top and tail, and trying a transition, and see if it still happens.
    Sounds like a transition between 2 Long GOP files, and the wrong I-Frame is being referenced during playback. This is just speculation without more info.
    ~Michael
    .: michael kammes mpse
    .: senior applications editor . post workflow consultant
    .: audio specialist . act fcp . acsr
    .: michaelkammes.com
    .: twitter: @michaelkammes
    .: facebook: /mkammes
    Hear me pontificate: Speaking Schedule .
