Activity Forums Apple Final Cut Pro Legacy Glitch in Time Remap with Frame Blending Turned On
  • Glitch in Time Remap with Frame Blending Turned On
    Posted by Dan Shott on December 13, 2007 at 9:51 pm
    Hey everyone,
    One of our editors just noticed a problem with Time Remapping. When it is applied to a 720×486 clip the bottom few rows of pixels are off from the rest of the image. I took a screen grab of it which can be seen here (it shows up on our external monitor too) https://www.flickr.com/photos/21358776@N02/2108679283/
    As soon as frame blending is turned off all of the pixels line up like normal. This also doesn’t appear to happen in 720×480 sequences. Anyone have any ideas at what’s causing this/how to fix it/have a work around?
    FCP 6.0.2, OSX 10.4.11, Quicktime 7.3. Seen on both a G5 and Mac Pro
    -Dan
    Flame Blend 486
    Rafael Amador replied 18 years, 8 months ago 2 Members · 3 Replies
  • Rafael Amador
    December 14, 2007 at 5:23 am
    Hi dan,
    you are not the only one. I posted about the same problem and Jeremy too treee or for days ago.
    I have the problem when I have the clip with the Shift fields filter and I try to change the speed with the Frame Blending on. If no Frame Blending, no problem.
    What I doing is to nest the clip and then apply the Speed change. Like that renders fine.
    cheers,
    rafael
    PPC G5 2x2Gh 4GbRAM/BlackMagic SD/PMBP 17″Core2Duo 4GbRAM
    JVC DTV-17″/FCS2/AE CS3/COMBUSTION/SHAKE
  • Dan Shott
    December 14, 2007 at 6:22 pm
    Hey Rafael,
    Thanks a lot for the response! Unfortunately I am still seeing the problem when the clip in nested. I’ve tried putting the clip into a new sequence, using the Nest Item(s) command, and applying the speed change to the new sequence and the clip inside it. Is there something that I’m missing?
    -Dan
  • Rafael Amador
    December 15, 2007 at 3:44 am
    Hi Dan,
    the truth is that I’m only having problem with the Shift fields+Speed?Frame blending.
    Please have a look to the threads of the last week. Jeremy G. is having the same problem than you. He nest the clip with the “Desaturate” filter (with a value=0) so this force the rendering of the nested clip. Have a try.
    rafael
