Activity › Forums › Adobe After Effects › glitch in the wiggler? (AE CS3)
Joe Mcneilly
April 2, 2009 at 3:59 pmUpdated: after controlling wiggle with a few expressions, the Wiggler decided to start erratically working again. I’m really stumped as to why it works sometimes and not others. The glitch seems to be that it will write the keyframes but not alter the attribute. To be fair, expressions do the same job, but I personally find it disruptive to have to mentally shift into writing javascript while working visually/creatively. As I get more comfortable with expressions, I suppose that will change. Hope this helps anyone else who is experiencing a similar problem =)
Peter Van der zee
April 2, 2009 at 4:30 pmAfter you’ve been wiggling a bit with expressions, you’ll not want to use “the wiggler” anymore
there’s so much more control writing this simple expression and it leaves it free of keyframes. -
Joe Mcneilly
April 2, 2009 at 4:41 pmi can definitely see the upside to not having keyframes – then if i wanted something to wiggle while moving across the frame i could do it without nesting sequences.
