Activity Forums Adobe After Effects Glitch Effect
  • Lothar Wieland
    January 8, 2015 at 11:08 am
    saw this here with photoshop, maybe you can do it same way in ae in case of image sequences. https://www.photoshopessentials.com/photo-effects/photoshop-background/ (step 5).
  • Graham Macfarlane
    January 8, 2015 at 4:27 pm
    Hi Rob,
    Seems to me that there are a few different things going on here. Stretching, offsetting, and general noisy blocks of pixels.
    I would look into using Video Copilot’s Twitch and possibly use it to drive the timing of a variety of displacement and directional blur effects on an adjustment layer(s).
    The displacement effect can be displaced by precomped subtle fractal noises (perhaps set to subscale, block, with low contrast)
    The adjustment layer can be masked either by hand or with a combination of keyed footage layers to get some quick and interesting alphas.
    I’m sure if you played around with these elements you could drum up something similar.
    Graham Macfarlane – 3D visualisation and VFX
    3D Studio Max | Vray | Pflow | PhoenixFD | After effects | Mocha
    http://www.elyarch.com – London UK
