Activity Forums Zaxwerks Glintwerks causing crash
  • Glintwerks causing crash
    Posted by Jody Wilson on January 9, 2009 at 11:39 pm
    I was wondering if anyone else was experiencing this problem, and whether there is a solution. I am using Glintwerks in AECS3 on an Intel Mac running 10.5.6. It causes the program to crash intermittently, even if the effect is turned off. Also, when rendering, it seems to inhibit After Effects from moving to the next item in the queue if it is applied within any comps in the queue.
    I suppose the best solution would be to not use this plug-in, but I really like the look of it.
    Any help would be greatly appreciated. Thanks very much.
    Tom Daigon replied 17 years, 7 months ago 3 Members · 2 Replies
  • Matt Rhodes
    January 12, 2009 at 4:43 pm
    Hi Jody.
    First, make sure that you’re using the current version of The Werks (currently at 1.5.0):
    https://zaxwerks.com/download
    Secondly, if you could send me one or two of your sample scenes with a few instructions to follow, I’d be happy to take a look. I should only need the .aep file – no media files necessary.
    Send files to: matt@zaxwerks.com
    Thanks.
    Matt Rhodes
    Zaxwerks, Inc.
  • Tom Daigon
    January 31, 2009 at 11:44 pm
    Jody, try turning off the Multiprocessor in the Preferences and see if it still crashes.
