Activity Forums Maxon Cinema 4D glimmer texture
  • glimmer texture
    Posted by Gerrit Velthuis on August 20, 2013 at 10:03 am
    I need to make an almost black object which has small glimmers in the surface, which means that they only light-up in the specular areas.
    I made a texture for it in PS; a simple black area with irregular tiny white spots, but I don’t know in what channel(s) to use it.
    The spots should only appear in the specular areas and not in the darker parts. The specular channel however doesn’t have a “texture” option.
    I tried different configs in the specular color channel but with no result.
    I attached an image to show what it should (more or less) look like.
    6427_glimmer.jpg.zip
    Gerrit Velthuis replied 13 years ago 2 Members · 2 Replies
  • Adam Trachtenberg
    August 20, 2013 at 3:52 pm
    R14 has a texture slot in the specular channel. With prior versions you would put the texture in the Specular Color channel.
  • Gerrit Velthuis
    August 20, 2013 at 4:43 pm
    Thanks Adam, that did it.
    Tried it before but after tweaking some parameters I got a reasonable result.
