Activity Forums Canon DSLR Cameras Glidecam and 7D – jitter/blinking issue
  • Glidecam and 7D – jitter/blinking issue
    Posted by Oleg Solod on February 14, 2012 at 2:20 am
    Hi
    Below is a link to a video, for some reason I am getting this jitter, almost like blinking with-in the frames while flying the 7D with 16-35mm lens. It doesn’t happen all the time but it does occur quite a bit. Seems like if I try and record in 720p at 60 frames I don’t see anything at all but at 24fps its quite apparent at times.
    https://www.youtube.com/watch?v=Ct1k79h_h2c
    My shutter would normally be set at double the frame rate, so for 24, I would set it at 50 and at 30 fps I would set the shutter to 60.
    Any advice or thoughts ?
    Oleg Solod replied 14 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
