Activity Forums Maxon Cinema 4D glass marble shader
  • glass marble shader
    Posted by Wolfgang Schwarzenbrunner on April 17, 2012 at 8:36 pm
    hi…
    actually i am working in after effects most of the time. right now i have to realize a simple glass-ball-hits-another-glass-ball animation. i dont have any troubles with the animation and the physics in the shot. what drives me mad right now, is that i dont manage to produce a shader that resembles the look my client wants to see. he gave me a photoshoped still of what he is thinking of (see attached image). i tryed around with some glass shader tutorials and ended up putting glass orbs into glass orbs to achieve something like a refraction within the glass. – but still i dont get to what i want to achieve. maybe someone could give me a hint…
    best
    Brian Jones replied 14 years, 4 months ago 2 Members · 4 Replies
  • Brian Jones
    April 18, 2012 at 4:31 am
    trying to copy the actual construction of a marble could help, it’s colored glass and clear(er) glass kind of wound together with a clear coat on the outside. Here’s a test that isn’t exactly like your ref image (but that is photoshop) and the inner bit should be rounder edged not so sharp I think but for what it’s worth…
    3991_marbletrial.c4d.zip
  • Wolfgang Schwarzenbrunner
    April 18, 2012 at 3:06 pm
    wow thanks… that was fast. i just have problems opening your file (unknown file type). i guess its because i am working on r11… i m going to update to r13 and look at your file…
    i also tried to “rebuild” a real marble – but i have troubles to get one of my glass shaders to appear like “solid glass” not just a thin hull…
    best and thanks a lot!
    wolfgang
  • Brian Jones
    April 18, 2012 at 8:47 pm
    I had trouble deciding from your reference pic whether it was the kind of marble I described or one that was all the same color with just a small transparent coating, if it’s that you are thinking of then you need something slightly different I’ll try that too later
  • Brian Jones
    April 19, 2012 at 1:22 am
    here’s a try at the solid core with a clear coating marble
    3996_marbletrial2.c4d.zip
