Activity › Forums › Adobe After Effects › Giving and image 3D “Thickness”
Posted by Msobetzko on May 16, 2005 at 5:01 pmI want to use photo images in a 3D evironment. The photos should look like they are cardboard cut outs that have some “thickness”. How can I add this depth to a photo?
Mike
Sam Turner replied 21 years ago 5 Members · 5 Replies -
Dan L.
May 16, 2005 at 6:38 pmTry Invigorator Pro. Our copy of After Effects had that bundled in. It can extrude objects, etc.
Mylenium
May 16, 2005 at 6:57 pmBuild some cubes with 3D Assistants lite (comes with AE 6.5 which Invigorator no longer does) and make one of the faces your image.
Mylenium
[Pour Myl
Sam Young
May 16, 2005 at 8:07 pmapply the shatter effect to the layer, but adjust the depth/radius/strength parameters so that the layer doesn’t explode. then adjust the extrude thickness parameter to your liking. shatter can also recognize the movements and perspective of a 3d camera layer in the same comp.
Msobetzko
May 16, 2005 at 10:35 pmGreat suggestions folks (all of them), thank you. I will try these tonight. I love how many ways there are of accomplishing the same thing.
Mike
Sam Turner
September 8, 2005 at 10:55 ami have tired using invogorator for this but cant get a photo to sit correctly on the 3d shape, when it moves bits of the 3d shape bleed out adding a border
the effect im after is to have a photo sit on a box and then animate the camera to look around it
any ideas?
ds
