Activity › Forums › Adobe Premiere Pro › Giving a workstation one more shot. Specs included. Opinions wanted
  • Giving a workstation one more shot. Specs included. Opinions wanted
    Posted by Duke Sweden on February 3, 2017 at 11:23 pm
    I remember the z800’s Xeon x5570 processors weren’t all that. Does this sound like it could be something you guys would use if you had to?
    Processors:
    2x Quad-core Intel Xeon X5570 processors with hyper-threading (8 Cores, 16 Threads)
    Supports Xeon 5500 and 5600 series processors
    Chipset:
    Intel 5520 (Tylersburg) Chipset
    Memory
    48 GB, DDR3, 1333MHz, ECC Registered
    Graphics
    EVGA GTX 970 4GB VRAM
    1 x HDMI 2.0
    1 x DisplayPort 1.2
    1 x Dual-link DVI-I
    1 x Dual-link DVI-D
    Hard Drives
    Drevo X1 240GB SSD
    Toshiba 2TB HDD
    Power Supply
    550 Watt Seasonic SS-550HT Power Supply
    +12V Rail Output: 41A
    Audio:
    Included PCI internal audio sound card
    I/O:
    2x USB 3.0 (rear)
    6x USB 2.0 (2x rear, 2x front, 2x internal [2x more available on header])
    6x Sata 3Gbp/s
    2x LAN Port
    1x VGA Port (Not supported with discrete video card installed)
    1x Serial Port Fast UART 16550
    1x (x16) PCI-E 2.0 slot
    2x (x8) PCI-E 2.0 slot
    1x (x4) PCI-E slot
    2x PCI 32-Bit slot
    12x 240 pin Dimms
    Case:
    Brand New Phanteks Enthoo Pro M
    3x Internal 2.5″ Drive Bay (Brackets not included)
    2x Internal 3.5″ Drive Bays
    5.25″ Drive bays have been removed
    Cooling:
    2x Cooler Master Hyper T4 CPU Cooler
    1x 140mm fans
    6x 120mm fans
    Operating System:
    Windows 10 Professional 64-bit OEM
    Duke Sweden replied 9 years, 7 months ago 5 Members · 16 Replies
  • 16 Replies
  • Duke Sweden
    February 3, 2017 at 11:57 pm
    And, remember, I’m an amateur, I make stupid comedy videos with a lot of green screen, some effects, I’m not working on the final version of Indiana Jones and the Temple of Shmucks, I don’t have a team I have to keep up with. Those of you who remember my nightmares with the z800, just give me your opinions of the components listed and if, together, they would provide a pleasant experience. Thanks
  • Andy Patterson
    February 4, 2017 at 1:03 am
    A mediocre 4.2 GHZ Kaby Lake CPU with 16 GB of RAM and a GTX 1080 would probably work just fine for your needs. Having said that wait until the Zen CPUs form AMD hit the market next month. The Zen CPUs may or may not be a game changer for video editors.
  • Tero Ahlfors
    February 4, 2017 at 7:08 am
    I wouldn’t put my money on almost 10 year old processors unless that package would be really cheap.
  • Duke Sweden
    February 4, 2017 at 12:58 pm
    How does $720.00, shipping included sound?
    And, Dave, I’m surprised a “pro” like you thinks a GH4 is fancy-shmancy.
  • Tero Ahlfors
    February 4, 2017 at 3:24 pm
    [Duke Sweden] “How does $720.00, shipping included sound?”
    Not that bad. That said a “basic” modern i5 or i7 CPU will still probably be faster in your use unless you’re is doing a lot of parallel computing (like exporting multiple versions from one file at the same time).
    You could probably get a new ready to go Asus/Acer/whatever desktop computer with that money.
  • Duke Sweden
    February 4, 2017 at 4:26 pm
    Ah, but which ONE!!!????!!!!!
  • Duke Sweden
    February 4, 2017 at 7:02 pm
    Well, if it makes you feel better, the only reason I could afford this is because my wife died and had a small life insurance policy. Happy now?
  • Ann Bens
    February 4, 2017 at 7:03 pm
    Post your question on Adobe Hardware forum.
    You will get very good advice.
    https://forums.adobe.com/community/premiere/hardware_forum?view=discussions
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
  • Duke Sweden
    February 5, 2017 at 2:49 am
    Thanks Ann but they don’t know me there and will assume I’m some video editing big shot like Dave LaRonde ????
    Anyway, I’ve given up BUT… I found this one with specs that blows away anything I’ve ever seen before (in my world, of course, not you guys). Some places mistakenly say DDR3 but RAM is definitely DDR4. All for under $1,000.00
    So I’m giving it one last shot. If you guys can pick apart THESE specs then there’s no hope for me. So have at it…..NOW!!!
    Product Description
    ThermalTake Overseer RX-I Full Tower Case
    Front 200mm Fan (600rpm, 13dBA), Top 200mm Fan (600rpm, 13dBA), Rear 120mm Fan (1000rpm,16dBA)
    3×5.25″ External Drive Bays, 5x 3.5″ Internal 3.5″ Drive Bays
    2x USB 3.0 Port (via internal header), 2x USB 2.0 Port, 1x eSATA Port, 1x Microphone, 1x Speaker
    Thermaltake 750W Power Supply
    80 Plus Bronze Certified, Ultra silent 140mm 2300 RPM ± 10% fan with intelligent RPM control
    Heavy-duty protection circuitry of Over Current, Over Voltage, Under Voltage, Over Power and Short-Circuit protections
    Supports multiple core high-end graphic cards & CPU (NVIDIA SLI & ATI CrossFire Ready)
    Gigabyte Intel Z170XP Series Motherboard
    2xUSB 3.1 Ports (1 rear, 1 Type C), 7xUSB 3.0/2.0 Ports (3 rear, 4 via headers), 6xUSB 2.0/1.1 Ports (2 rear, 4 via headers)
    6xSATA3 Ports (Raid 0/1/5/10), 3x eSATA, 1x M.2 Port, 1xPS/2 Keyboard/Mouse Combo Port, Audio Jacks
    Kingston 64GB DDR4-2400Mhz PC4-19200
    Intel Core i7-6700K 4.0GHz Skylake Processor Turbo Boost 4.2GHz, 8MB, LGA 1151
    Corsair H75 Hydro Water Cooler Dual 120mm Fan, Speed: 1700RPM +/- 10%, Noise Level 30 dBA
    Samsung 850 EVO Series 1TB Solid State Drive
    2X 5TB Western Digital Blue SATA-3 6.0Gb/s 32MB Cache
    nVidia GeForce GTX 1080 8GB Video Card
    12X LG Blu-ray
    Wireless-N PCI-x Adapter 300Mbps
    115dB SNR HD Audio with Built-in Rear Audio Amplifier
    Audio Noise Guard with LED Trace Path Lighting
    High Quality Audio Capacitors
    Intel® GbE LAN chip (10/100/1000) Mbit
    cFosSpeed Internet Accelerator Software
    MS Windows 10 Pro 64 Bit
    High Quality Brand Name Components, Assembled and Tested, 3 YEARS Parts and 3 YEAR Labor Warranty
    Product Information
    Summary
    Processor 4 GHz Intel Core i7
    RAM 64 GB ddr4
    Hard Drive 10 TB
    Graphics Coprocessor geforce gtx
    Hard Drive Interface Serial ATA-600
  • Chris Wright
    February 5, 2017 at 3:21 am
    well, its not 10 years old this time…but its still 4 cores and a generation older than 7700k, and Premiere likes 6 or more cores for 4k.
    https://www.pugetsystems.com/labs/articles/Premiere-Pro-2017-Intel-Core-i7-7700K-i5-7600K-Performance-884/
    https://www.pugetsystems.com/labs/articles/Adobe-Premiere-Pro-CC-2015-3-CPU-Comparison-849/#Conclusion
    also, you would need at the minimum, a 850 evo for os/apps/render output/media cache/
    and another 850pro or 960 evo for media/project files
    minimum 1060gtx or 1050ti. 32gb ram.
    I mean, you could get what you need and have good results without having to cut corners for the same price. you just need a vendor that won’t rip you off.
