Activity › Forums › Adobe After Effects › Gilding Effect
Gilding Effect
Posted by John Wilkins on May 29, 2007 at 11:26 pmCould someone give me a hint on how to go about creating an animated gilding effect (like below)
https://img111.imageshack.us/img111/9946/gildinghm1.jpg
I think shine my be a little harsh. Is a luma matte the best way to go?
Cheers
Nate Vander plas replied 19 years, 3 months ago 6 Members · 6 Replies -
David Bogie
May 30, 2007 at 2:17 pmYou have to create a mask of the area that is covered in the gold foil and then figure out what effect to use. Shine would not be where I’d start since this is just a color, not an active effect, unless, of course, you’re going to animate the light source. That would require an easier-to-draw mask.
Your sample image is complicated with lighting from only one side and there is much variation in the surface texture of the skin. All this can be created in AE but, like most simulations, it will never really look like illumination from a scriptorium.
bogiesan
Tyler Paul
May 30, 2007 at 3:14 pmTo make the foil look shiny I’d try making a masked duplicate of the foiled area and set it’s blend mode to add. Adjust the opacity. To animate it I’d maybe add colorama with a gold colored gradient and animate it’s rotation. This should make the foil look like the light source is moving as dark parts become light and light parts become dark.
I wish I had AE in this edit bay so I could test it out.
“Life Should Come With Backround Music”
-Brown Sugar Studios- -
Darby Edelen
May 30, 2007 at 4:56 pmIf you’re in the mood for something quick and easy Effect>Stylize>Texturize can help you get some decent texture/light effects, similar to bump mapping only it doesn’t respond to AE’s 3D lights (although I’m sure you could write an expression to do so).
Darby Edelen
DVD Menu Artist
Left Coast Digital
Aptos, CA -
Mike Procunier
May 30, 2007 at 6:00 pmI’d find a large image of gilding or metal texture online (istockphoto.com perhaps) and matte it into the desired area. You could even take a digital photo of aluminium foil and colorize it in AE. Maybe put a subtle grunge texture on top to rough it up a bit.
John Wilkins
May 30, 2007 at 10:25 pmThanks guys. I’ll do some experimenting and post what I come up with.
Nate Vander plas
May 30, 2007 at 10:57 pmI’ve done it before by using fractal noise, stretching it vertically, and then colorize with a tweaked gold preset. If you wanted it to be bumpier you could use a photo of a bumpy surface and use it as a displacement map for the fractal noise layer. Here is what mine looked like:
Fake gold glint
It is very near the beginning on the “Calvin Engineering” letters.
Hope this helps!
Nate
