Activity Forums Compression Techniques Gif / Giphy Stickers
  • Gif / Giphy Stickers
    Posted by Tj Smith on September 24, 2019 at 8:47 pm
    Anyone out there making stickers for Instagram stories with giphy?
    Trying to figure out the ideal workflow for getting quality transparent gifs and I can’t quite seem to get the image quality other users are achieving.
    To start, my process is typically –
    Adobe After Effects, Render to PNG Sequence with RGB + Alpha Channel, Import PNG Sequence to Photoshop, Save for Web & Devices with no matte and set forever loop.
    My issue is im losing a lot of quality on the text even though the source quality seems fine. I understand there will be some compression, but is there a way to get better quality? Possibly a lower FPS? The goal is to be able to scale the sticker with minimal issues but as you can see below there is quite a bit of quality loss.
    Compare ::
    IG – https://imgur.com/a/3A3zcJU
    ORIGIN – https://imgur.com/a/OpEqF6K
    TLDR – Any tips for maintaining quality when making transparent GIFS for Giphy / Instagram Stories?
    View post on imgur.com
    Tj Smith replied 6 years, 12 months ago 1 Member · 0 Replies
  • 0 Replies
