Activity › Forums › Adobe Photoshop › GIF Animation
GIF Animation
Posted by Kesiena Uvietaire on April 20, 2010 at 12:30 pmI need a step by step approach on GIF Animation and its rendering using Photoshop tools. Any help guys?
Thanks in advance!Kesiena Uvietaire replied 16 years, 5 months ago 2 Members · 2 Replies -
Matt Sepeta
April 21, 2010 at 5:58 pmSuper easy!
Assuming you are in CS4-
Window>Animations to open your animation palette
Make sure the “Animation” tab is open, not the “measurement” tab.
Hit the new piece of paper looking button in the animations palette to duplicate your current frame. This creates a copy of your “canvas” for the next frame. From here, you can change your layers and everything without affecting your previous frames.Play around with it, its probably the easiest way to animate things, granted, the results can look pretty terrible if you are trying to keep it under 50KB for banners/
Good Day
http://www.mattsepeta.com -
Kesiena Uvietaire
April 21, 2010 at 8:34 pmThanks akot. But how can I render it to GIF so that the entire frames play in loop?
